Old 12-29-2011, 03:41 PM   #1 (permalink)
NachtRitter
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
VW TDI - 60+ mpg and 900 miles on one tank!
Took a 'long' trip over the holidays with Helga, the 2000 VW Jetta TDI I own. Nearly 850 miles from point to point (Sacramento, CA area to Spokane, WA area, then back some days later). I thought I might be able to make it on one tank but on the way up I decided to fill up when we stopped for lunch. On the way back I decided to go for it all the way and made it with a quarter tank (indicated) left... Woo!
Car was loaded with family and luggage and I didn't do any special hypermiling techniques... just kept it at or below the PSL. I've done a few mild mods to the Jetta, including larger injector nozzles, a 'Stage 1' tune by Rocketchip, a taller 5th gear (0.681, which is not the tallest available), and a grill block. Also have LRR tires inflated to ~50psi.
Fillup at 900 miles on the trip odo showed I still had another ~2 gallons (and then some) left, so in theory I could've made it to 1000 miles on the tank!
Definitely impressed with the MKIV TDI's... they definitely seem to make it easy to wring out some amazing FE numbers without much effort!
