Old 01-03-2012, 03:40 AM   #24 (permalink)
drees
Originally Posted by Ladogaboy View Post
Not only that, 300 miles seems EXTREMELY optimistic for the Tesla.
The 300 mi range number is an "ideal range" for the 85 kWh battery car which means driven at 55 mph. "Real life" range will probably be about 70-80% of that number. Similar to how the LEAF is called a "100 mile" car, but in real life it's more like 70+ miles.
Originally Posted by Photonfanatic View Post
Maybe if you didn't mind stopping and plugging into say... a light pole or a car wash's outdoor plug for an hour... I don't know.
Charging stations will become more popular - but your typical station today is able to recharge at a maximum rate of about 24 miles / hour. Quick charge stations are be able to charge from near empty to 80% in about 30 minutes. Your typical 120V outlet? 4 miles / hour.
Also what happens when the battery starts to develop a "memory"? Don't you need to run a battery all the way down in order to avoid that?
No memory issue with lithium batteries used in modern EVs.
