Old 01-03-2012, 01:17 PM   #30 (permalink)
drees
Originally Posted by drmiller100 View Post
Ethanol is "rechargable". If you get SERIOUS about the economics, ethanol can indeed be made and sold for a profit at today's gasoline prices. This tells me it makes economic sense.
Brazil has been doing it for many years.
The real problem with the current crop of "affordable" biofuels is the amount of land it takes. It will never replace a major portion of current fossil fuel use - the energy return and land use is simply way too high. It is likely to eventually replace fossil fuels where energy density is a must (think jets).
The "Do the Math" blog has a great post on this: The Biofuel Grind | Do the Math
Originally Posted by jamesqf View Post
Batteries are chemistry, and burning gasoline in an IC engine is chemistry. So is there IN PRINCIPLE any reason a "battery" couldn't store as much energy in some reversible reaction as could be stored in an equal weight of gasoline?
Yes, this "battery" you describe would be called a fuel cell. These are also likely to replace fossil fuels for energy intense applications (long haul trucking is a good example) but will likely still include some amount of traditional batteries or super-capacitors as current fuel cells do not like to change power output rapidly.
