Old 01-05-2012, 05:58 PM   #5 (permalink)
darcane
darcane's Avatar
Originally Posted by Peter7307 View Post
Hillman in the 1960's built a rear engined car named the Imp which had a radiator ducting into the rear panel and the intake was on the rear deck where the trunk / boot would normally be.
Apart from adding a little weight at the rear and having the extra pipework to take the fluids to and fro there seems to be few downsides.
Peter.
For a mid-engine car, there would be far less "pipework" than having a traditional radiator. I had a 1991 MR2 which has the radiator up front. Getting the air out of the coolant lines was a little tricky because they were so lengthy, running under the passenger compartment to the nose of the car. They could have easily put the radiator in the goofy mini-trunk behind the engine and saved a lot of plumbing.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
