Old 01-06-2012, 01:18 PM   #17 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by Ken Fry View Post
So, if you pull out the stops, you get something that looks like this:
(Photo of Nuna5 from gizmag)
No Hucho template upper curve, no blunt leading edge: just impeccably clean everywhere, not just at the tail.
Thanks. I appreciate all the replies to this thread, but I am still learning, which is why I ask. Isn't the Nuna5 solar racer partly shaped for maximum solar panel space? I imagine something like this...
Human Powered Vehicles (HPV)
... if you pull out all the stops.
I've already said this, but your contention that it all counts is correct. The Mooney 201 and 231 aircraft were famously clean, because of attention to a great many details.
Can you post a photo?
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
