Old 01-07-2012, 08:40 AM   #8 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Originally Posted by jakobnev View Post
Having the switch be a relay that is controlled by the no-charging (or no oil pressure) light seems simple enough.
Did you see this thread: http://ecomodder.com/forum/showthrea...uce-16992.html
An alternative is to have the extra batt supply current to your main batt trough a voltage regulator. That way it just regulates the voltage the same way the alternator does, and automatically increases the current when the alt drops out.
Good ideas. I don't know enough about voltage regulators; I see a new research venture coming on.
Coast long and prosper.
