Old 01-07-2012, 05:55 PM   #28 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Originally Posted by IamIan View Post
Best of luck.
Thanks! And thanks for the additional suggestions. One comment and one quick question:
I had another specific suggestion that it may be advantageous to remove the sticks for testing specifically to keep tabs on which cell/s is/are getting particularly hot during charging. Might be a useful data point to have.
But it certainly speeds up the process by leaving everything in place.
Question (pardon my noob-ness):
#3>Note the subpack internal resistance estimate for each stick ... what is the change in terminal voltage from the resting state to the discharging state at a known amount of amps ... V=IR ... this can be noted during the above discharge capacity test.
Good idea. But since voltage begins falling as soon as the discharge begins, at what point do I record V to get a best estimate? 1 second after starting to discharge? 10?
