Old 01-07-2012, 08:07 PM   #5397 (permalink)
bennelson
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
[QUOTE=Ken6881;278393 when you hit a bump it would break connection restarting the controller. [/QUOTE]
I had the same issue with a Curtis controller on a Citicar.
The Citicar has a switch on the parking brake. That switch would loosen up. While driving along, it would cut out, and remove power to the main contactor.
I don't remember the exact wiring on that. It may have turned off the main contactor AND turned off the controller I'm not sure. Anyways, I would have to pull over (while still coasting, and trying to figure out what happened) Then fiddle with the switch, and everything would be fine again.
I never had a problem with the controller because of it though.
I am excited about the "pre-charge AND contactor controll built-in!" features of the new Open ReVolt.
I just have to do some work on the case and mounting it, and my Electro-Metro will be running the 1000 Amp controller! (I still need to find a 1000 amp fuse though!)
Not sure what my 300 amp ammeter is going to think of it either. I guess it won't mind being pegged while I do a burn-out!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
