Little update here: Adjusted the grille block moving the space to the middle. I'm surprised how flat the block turned out to be. My rear lower control "arms" are just tubes, so I connected both bars with plastic. I assume it will aid in smooth airflow, but I could also see it just being an airblock. Did waste much time on it so no loss. I ordered a rear visor that goes at that top of the hatch. I'm torn as to whether it will do anything at all. I haven't seen a good angle of it, so we'll see when it arrives.
RETIRED
