Old 01-09-2012, 04:54 AM   #24 (permalink)
oil pan 4
The DB2 serries can pump anything as long as you dont over do it.
I have burned many gallons of used motor oil, used vegetable oil, used hydraulic fluid, used turbine engine oil. Used motor oil causes you to go through a lot of fuel filters, thats why I use a G3 fuel filter as a primary $3.50 each and they last at least 3 or 4 months and with my more powerful duel electric fuel pump setup they should last a lot longer.
