Old 01-09-2012, 04:01 PM   #29 (permalink)
oil pan 4
Originally Posted by euromodder View Post
The diesel conversion is going to cost a lot; diesel is more expensive in the US; and these cars are unlikely to be driven the kind of miles that would make diesel operation economical; swapping in a 6+ L diesel is hardly an economy measure.
GM killed the diesel car market in the US a long time ago and our government works to surpress diesel applications in anything but heavy duty passanger pickups and vans so all we really have for easy to get old diesel engines are these old truck engines.
Those old battleships often have plenty of space, why not add LPG to a petrol engine ?
The same thing can be done with diesels with intake fumigation you can run them off both LPG and diesel while being able to still run off diesel alone.
Originally Posted by Ladogaboy View Post
You could probably get away with swapping in ~ 2.0L diesels (with or without turbos) and be fine.
The problem with non-turbo diesels in the 2L range is they are only going to put out about 50hp.
