Old 01-10-2012, 02:17 PM   #233 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Tomorrow I should pick up a new engine tray. The original tray had (green) foil glued to the middle to reflect the oil pan's heat, the new one probably doesn't (it's made by a local company, not OEM). So what could I glue to the new tray (kitchen-grade alu foil, 2mm styrofoam with foil on one side, ?), and what kind of glue will hold it to the HDPE tray in extreme heat/cold/moisture? I was wondering if I should cover one whole side, instead of just the middle, but I doubt that would make any difference in warm-up or cool-down times.
