Originally Posted by sawickm
mrbigh,
What kind of charger are you using ?
Please keep the Revolt forum updated on your project connecting the charger to the J1772 interface module !!!
-Mark
That module isn't doing very much. It's pretty much just a diode, two resistors and a relay that switches the second resistor into the circuit.
It would be more interesting if the board did more: provided an isolated pulse width signal to the charge controller (the allowed current draw is indicated by the pulse width), provided a motor controller "inhibit" output, or sent a CAN bus 'connected' message.
