Originally Posted by 320touring
how far along the a720 do you have to go to get to work (what Junction?) ever considered the "Midlothian" side of things? penty roads that run parallel
I come off at Straighton, and there is only the sort road by the 720 from the ski place I think. Plus Midlothian has more traffic lights (permanent and temporary) per mile than anywhere I know.
Thanks to this traffic "management" I come off and then go through LoanHead instead of using the main road - there are 11 sets of lights in 1 mile that way.
where did you get the sidelights? tempted to get them and led indicators for the BMW- reduce the current consumption.
The bay of flea was my source for the LEDs - nothing fancy, just the ones Halfords do too - no idea if they make a difference to current consumption but they are brighter so I can use the headlights less - which has an effect on GPH.
Headlights will get the 50% brighter h1 (55w) bulbs, as I'm a fan of seeing where I'm going
Osram Nightbreakers are the ones I have been recommended and may switch too as I find the standard lights a little dull, or I'm getting old - again.
