Old 12-30-2011, 10:08 AM   #171 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Arragonis View Post
Worryingly this new engine is not massively smaller than George's real engine...
LOL
You could remove the fan belt and get an electric fan for it
Old 12-30-2011, 12:35 PM   #172 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Imagine the weight savings if you swapped it in
Old 12-30-2011, 01:09 PM   #173 (permalink)
The PRC.
Originally Posted by 320touring View Post
Interesting to hear what you're saying re the WAI- I imagine the electronics used to meter air intake in your engine are too complex to be fooled by the "hot air" arguement...
Mine,on the other hand...
I think its much simpler than that - because the intake "box" is directly on top of the engine it gets to a specific temp all the time, so there isn't any effect of the WAI vs not using it. So the electronics are not getting any warmer temps than normal anyway.
The installation in the original Daihatsu the engine was designed for have a device which may help with faster warm up.
Old 01-13-2012, 06:01 AM   #174 (permalink)
The PRC.
Update - the Electric motor has proved to be a bit of a failure - Mrs A has banned it from running due to noise - maybe if I added Slick 50 ? Also the cam-belt mechanism has proved to be unreliable allowing the timing to slip by a tooth or so on the belt. It will only get worse.
Tried an alternative route around Edinburgh - basically going the other way around the city instead of the route I normally take. The distance is about the same, maybe an additional mile in the new route compared to the normal one.
In the mornings it really isn't a starter due to the time it takes because of traffic - roughly 50% longer depending on when I set off.
On the way home though it takes about the same time - maybe 2-5 minutes more - and the traffic flow is more "hypermile friendly" - i.e. no crawling traffic, you are either moving or not so the engine can be shut off. Got an average of 82.3 using that route vs high 60s on my normal route. I need to try it a few more times to check traffic flows now that people are getting back into the miserable existence of working in Edinburgh after the break.
<SmallRant>Edinburgh is a city where the council hates people using cars but allows the building of things like shopping centres and zillions of new shopping centres, apartment blocks, and even the offices of uk.gov in Scotland by the waterfront, which means zillions of people want to drive there.
Buses are no use as they have to use the same roads and the new train set (i.e. the trams) don't go there - genius!</SmallRant>
And breathe.
EDIT - Other planned mods now I have some spare pennies will be LED tail and indicator bulbs - already have LED sidelights - and perhaps some DRLs on the front like the new Aygo has.
Old 01-13-2012, 08:20 AM   #175 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
And breathe.
I don't envy you, that top part is a nightmare! I have a garage I use in Restalrig, and getting in/out of there can be hellish.
how far along the a720 do you have to go to get to work (what Junction?) ever considered the "Midlothian" side of things? penty roads that run parallel
where did you get the sidelights? tempted to get them and led indicators for the BMW- reduce the current consumption. Headlights will get the 50% brighter h1 (55w) bulbs, as I'm a fan of seeing where I'm going
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
Old 01-13-2012, 08:35 AM   #176 (permalink)
The PRC.
I come off at Straighton, and there is only the sort road by the 720 from the ski place I think. Plus Midlothian has more traffic lights (permanent and temporary) per mile than anywhere I know.
Thanks to this traffic "management" I come off and then go through LoanHead instead of using the main road - there are 11 sets of lights in 1 mile that way.
The bay of flea was my source for the LEDs - nothing fancy, just the ones Halfords do too - no idea if they make a difference to current consumption but they are brighter so I can use the headlights less - which has an effect on GPH.
Osram Nightbreakers are the ones I have been recommended and may switch too as I find the standard lights a little dull, or I'm getting old - again.
Old 01-13-2012, 08:36 AM   #177 (permalink)
The PRC.
PS2 - of course the new Aygo facelift differs only in the front bumper shape - hmmm.
Old 01-13-2012, 03:57 PM   #178 (permalink)
aero guerrilla
Piwoslaw's Avatar
Are you lookiing for any, or almost any, LED DRLs, or would you like to fit the newer OEMs? In the latter case, would it be a direct replacement? I understand that they fit the new bumper, but what about the one you have? And if you were to replace the whole bumper, then would that be a direct fit?
Old 01-13-2012, 05:37 PM   #179 (permalink)
The PRC.
The current bumper I have doesn't have a space for DRLs - they were not an option even for a dealer fit when I bought George. A guy who does loads of bug modifications on a different forum is (apparently) doing a DRL conversion which fits into the foglight spaces and as I don't have foglights I may copy his method onto George. The Ring Lyra kit has all the wiring to make them road legal here - i.e. off with side and headlights, on with ignition etc. The limitations on height and distance from the sides is the tricky bit.
I was pondering the new bumper as I think it will be a straight fit, but I read someone had been quoted £300 just for the moulding, so when you add painting, fitting and the lights, well, maybe not. I could DIY it but my painting skills are rubbish.
It looks all of the bugs have been modified so that they all have the (Aygo) front wings and bonnet (hood) with the raised centre part, but different bumpers which would make sense to save money and also rationalise the production lines as the new bugs are due next year. I assume the factory is currently gearing up for that so one less different thing to worry about for them.
Old 01-13-2012, 06:37 PM   #180 (permalink)
aero guerrilla
Piwoslaw's Avatar
Same here, but that didn't stop me:
I got mine installed in about 2 hours (not counting the wiring). The only plastics I had to cut were behind the DRLs, and was only a few square cm.
It should be easy for you to find LEDs that fit between your grille's ribs - there are many, many more shapes and sizes available now than when I did mine 3 years ago
