Old 01-13-2012, 04:06 PM   #1 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Taller rear tires on RWD vehicle
I've been thinking over this potential mod for a while and wanted to get other's opinions. Would there be an advantage to running taller rear tires on a rear wheel drive vehicle (such as my pickup)?
The advantage of a taller tire is supposed to be lower engine RPM's becuase the powertrain has effectively been re-geared lower. Typically, however, people who go to taller tires (all around) see FE decrease. The thinking hear is that the taller tires hurt the aero because the effective frontal area has increased. Some people also cite the higher rotational mass. Another factor is that many taller tires, tend to generally have higher rolling resistances.
So here's my thinking. If you went to taller tires, but only on the rear of a RWD pickup, you'd get the gearing benefit without the aero penealty, right?
Anybody tried it?
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
