I run a deep cycle battery and disable my alt (but leave it in place). Much benefit. And I still can have access to it when I go for longer trips than my daily driving. That's the BIG plus.
Originally Posted by toc
Is that true of A/C compressors with the clutch as well?
You could still remove the A/C for weight reduction. I removed mine for that reason. All depends on your taste and tolerance.
