Old 01-13-2012, 10:25 PM   #7 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Considering the effort in removing + replacing the belt, I plan on leaving mine assembled. But I'm considering sorting out which of the four small wires in the connector can be severed to disable the alt and then rig a switch and/or relay to control it.
Most Hondas use a unique "ELD" circuit to control the alt; I read something indicating I might need to actually ground one of those wires - but I'm not betting on it.
Anyway, I plan to leave it assembled. For flat-out mpg competition, one might remove the whole thing, but it needs to be fully charged and your range is limited to how much of a charge you can load into your battery.
Coast long and prosper.
