Old 01-15-2012, 11:58 AM   #184 (permalink)
Arragonis
The PRC.
I removed the upper nostril block a while ago when it came loose - must "borrow" some more black zip ties from work and refit them. That would be a better option as you can get behind there more easily, but the upper nostrils are only just 600mm apart at the outer edges, George is too broad in the beam to qualify for the 400mm rule.
We don't want any problems with the fuzz...
...tapping of which time to wander over to a thread about a 318
I need to work out which DRLs will fit into the grill. I may fit them horizontally as you have them but in the same space I have them like PWs. The lower grill is blocked on the right (from the driver's seat looking forward) and the opening on the left is obscured by the radiator from the inside.
I also need to work out which is a decent kit and what other parts I might need. And whether I feel brave enough on electrickery. I want it to be proper, i.e. on with ignition and off with sidelights or headlights.
Any ideas on what is a decent kit, or a decent set on bay of flea and what else I might need ? Halfrauds has the Lyra kit which apparently includes everything you need, but they want £70 for it, ebay has it at about £40 but loads of lights being sold for less - often its hard to work out if they are all legal or not.
