Old 01-15-2012, 01:58 PM   #185 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by Arragonis View Post
I also need to work out which is a decent kit and what other parts I might need. And whether I feel brave enough on electrickery. I want it to be proper, i.e. on with ignition and off with sidelights or headlights.
My DRLs are wired to the cabin's accessory (lighter) socket, since it turns on and off with the key in ignition position. The other half is done with a relay which switches off when the headlights turn on (you can wire it to position lights, if you prefer). Not too hard to DIY, and much cheaper than £40.
The Following User Says Thank You to Piwoslaw For This Useful Post:
Arragonis (01-15-2012)
