Old 01-15-2012, 05:20 PM   #9 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by BackroadBomber View Post
I got slightly. Bigger tires on my ford ranger and I see a decent mpg increase, like 2 mpg. Also, the reason people think they get worse mileage is because people don't re-calibrate theirs speedo and odometer. A bigger tire will make your speedo read slower, so your odometer will show less miles than actual miles driven. If you put bigger tires on, make sure you get your speedo recalibrated, or if your trucks older like mine figure out the percentage it's off and factor that In to figure out your true mileage. Oh by the way the tires that are supposed to be on my truck are 225-70-14 and I put on 225-75-15 so they're around 2 inches taller and they throw my speedometer off by 7.11% (when I'm doing 60 my speedo will read 56). So whenever I fill up and want to figure out my mileage, I multiply the distance on the odo by 1.0711 and find out my actual miles travelled.
Glad to hear that you've seen a benefit. I've looked into it and you are one of the few that's seen FE go up. Certainly the speedo needs recalibrated for different tire sizes. From what I've heard, I'd say fewer than 1 in 10 people report better FE with taller tires (after speedo re-calibration).
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
