Oh, another thing I keep thinking about, but forget to mention is power steering/power brakes/ and anything else that normally runs off the engine.
In an electric car with a generator added, all those things are already designed to run without the engine. (My Metro has manual everything, except for power brakes, which was easy to correct by adding a small electric vacuum pump.)
In a parallel hybrid where a person would want it to be able to run either with the engine on or not, steering and brakes would need to be manual to start with (more typical on a lighter/older/simpler car) or converted to manual (such as swapping out the steering mechanism) or converted to electric (like I did with the power brakes on the Metro)
For me, starting with the manual everything vehicle would be the easiest way to go. A modern, front-wheel-drive crossover might be the MOST difficult to convert to still have steering and brakes with the engine off. I think that's also one reason why the EMIS system is designed as a "boost" instead of having any electric-only range - it means the original steering and braking systems never have to be modified in any way.
