To clarify, we are not concerned with improper use of LEDs in headlights because they haven't been around very long?
No, you missed my point.
If you google each, you will se there are not hundreds of 'plug n play' kits. also the technolog isnt 'quite' there yet.
But it all falls under the same issue (clearly) moving the hot point. Maybe that doesn't seem clear to you but that's the point of the conversation.
Frankly, op wasnt going to be able to 'create' a suitable alternative w/led. But he could drop $40 on your recommendation and think he did a 'good' thing.
