Old 01-23-2012, 08:25 PM   #2 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by fastegg View Post
Hi.. I'm new to this forum... I drive a '98 Lexus LS400 and my project for the next few years is. .. ... .... .....
> "To achieve the most possible HP with the least amount of fuel used"
> so my question is how instantaneous and accurate are the SG2 and UG ?
> And if used primarily to calculate fuel usage... even to notice changes in tire pressures, different air intakes, electric water pumps etc.... would they be accurate enough to detect these changes ?
> thank you dearly ...
I'm sure most here will say it's the MPGuino. After that, good calibration of an Ultra Gauge or Scan Gauge should yield about the same results. But I don't think they'll detect very small changes in the factors you mention. UG takes a sample every second, I think.
fastegg (01-25-2012)
