01-23-2012, 11:37 PM
no --- use a used MAF sensor
reading further down in this thread some have suggested measuring flow in the hi pressure injector lines
do not do that
you can measure flow in the supply line then subtract
measured flow in the return line
both are low pressure
which is not very practical but there will be none of the problems that will arise from an attempt to measure high pressure pulsed flow
air fuel ratio is not controlled so measuring incoming air will not help , but measuring incoming air flow can give you a relative value that you can minimize to maximize FE
you can use a MAF sensor that can be plumbed into your intake all you need is a 5 volt supply and a ground on a hitachi type MAF which were / are readily available
and you can put a scope on the MAF output and measure flow per cylinder
relative flow
all must be the same exact signature , you can easily pick off dirty valves or low compression or contributing cylinders
Originally Posted by BurningDinosaurBones
Can this work with my 1993 VW Golf Turbo Diesel? It has a belt driven mechanical fuel pump, throttle, and fuel injection system so there is no electrical involved in the fuel injectors as far as I know...
there is a later VW ALH engine at idle TDi engine, the green trace is a needle lift sensor on injector #3 , used to determine injector pump timing relative to the crankshaft which the red trace
the pizeo input "Needle lift sensor " is as usable for rpm as the crankshaft sensor waveform
or
a sensor near the flywheel teeth
blue
another pressure differential sensor measuring pressure change in the crankcase , blowby from the piston rings , all are uniform , good
Reason: ALH w Needle lift and ckp
