Old 01-24-2012, 08:06 PM   #5 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by ConnClark View Post
Why not just leave the alternator on for all the runs? Current consumption should be the same if you don't use the radio.
That's a good question, and Carlos/cfg83 has part of my answer. But it's also true that this Civic has the ELD/Alt set up that allows the ECU to modulate the power output of the alternator, and it does not seem to be completely regular under otherwise identical conditions. Maybe with a starting battery it would be, but not with my deep cycle. I watched the alt charge sometimes and not at others. And it was not always putting-out the same amount of power. Isolating the alt seems like my only way to control this factor. I have been looking more at some of the other test on here again too. The tendency is to build the skirts as close to the wheel as possible. I made a mistake leaving room there, I bet.
