Old 01-26-2012, 06:34 PM   #7 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by mattbatson View Post
Ok, so it sounds like the returns will be negligable...and hardly worth the expenditure.
thanks for all the responses
Did you read Sentra_SE-R's results in the link above? You could pick up two or 3 mpg, if his results are reliable. If the wheels come cheaply, then you win. In my case I got nearly new tires on my second hand-lightweight wheels when I already needed to replace the tires. The total cost of the wheels and nearly new tires was quite a bit less than buying new tires, having them mounted and balanced. I got lucky in that deal, but if you keep looking you could get the wheels for very cheap.
