Originally Posted by ceasar
Hello, maybe Vekke or other member know real work example, when somebody replace Lupo 3L semi-auto gearbox to manual from other Lupo? its difficult job if talking about matching points? I had conversation with one guy who said main problem is electronic, so you need know good electrician. I know that 3L awesome until your semi-auto gearbox broke  and in my country market you can find pretty good condition Lupo 3L with gearbox failure for 1k euro. Thanks for answers...
I think it will be easy to do that, i repair some lupos with this engine, and the gearbox ia a manual type with a robot to change gears, control clutch, citroen also use this system, it's called "robotized manual gearbox" in my country.
Tou just need to convert the gearbox and gearbox levers, access the car ecu and choose the manual type gearbox(it's on the original ecu and you can change it with vag-com).
Tuned VW Golf Mk4 Tdi, Euro spec!
AJM engine swaped by ASZ and many other goodies
