Old 01-27-2012, 03:31 AM   #69 (permalink)
Frank Lee
DynoValve ®
Improves Fuel Mileage
Reduces HC, CO, and NOx Exhaust Emissions
Laboratory Tested at EPA Approved Facility
The DynoValve ® is a newly patented Positive Crankcase Ventilation (PCV) Valve. The DynoValve is designed for use in Automotive gasoline powered vehicles. The DynoValve ® replaces OEM PCV valves. The DynoValve TM eliminates the vacuum problems associated with todays standard PCV valves by optimally regulating the flow of engine blow-by gases. SaVi Media Group, Inc. accomplished this unique ventilation with the use of an electronically controlled switch. The Electronically Controlled DynoValve ® precisely regulates the flow of blow-by gases returning to the engine intake system.
See that? Up there? That's about as much explanation of anything as you'll get. And it doesn't explain jack isht. I'll waste no further time on this unicorn crap.
t vago (01-27-2012)
