The sheet is presenting the results of 2000 Ford Lincoln Towncar, but the smog test readings are from Chevy C1500 Pickup 1997 ??? Why?
And you can see from the smog test readings that the Dynovalve increases the CO2. But the youtube video says that it will reduce carbon footprint. Which one should I believe?
Summer vehicle
My dad's tire pressure is much higher than your dad's!
