Old 01-27-2012, 10:36 PM   #64 (permalink)
NeilBlanchard
The FVT motors and the YASA motors are direct drive, and that torque is at the output shafts. On the YASA motor torque / efficiency graph, it shows it has that 750Nm (533ft/lbs) is available as low as ~100RPM. That would mangle most gears, and gears that are strong enough would lose power through friction. Heck, the YASA has peak efficiency of 94-95% without any gears!
