Old 01-28-2012, 02:00 AM   #88 (permalink)
iceQuity
The DynoValve ® is a newly patented Positive Crankcase Ventilation (PCV) Valve. The DynoValve is designed for use in Automotive gasoline powered vehicles. The DynoValve ® replaces OEM PCV valves. The DynoValve eliminates the vacuum problems associated with todays standard PCV valves by optimally regulating the flow of engine blow-by gases. SaVi Media Group, Inc. accomplished this unique ventilation with the use of an electronically controlled switch. The Electronically Controlled DynoValve ® precisely regulates the flow of blow-by gases returning to the engine intake system.
Increased fuel efficiency is created by blow- by gases returning to the engine intake system... Is how I understand it to work. Do I have one? Yes... Am I getting better MPG? Yes... By how much? It varies on the speed I travel. But on average its about a $4-$5 savings for me a day.
