Old 01-30-2012, 05:47 PM   #25 (permalink)
aerohead
difference
Originally Posted by Sven7 View Post
I see one big difference: The falcon's feathers point lengthwise while broom bristles would face crosswise. When the air is going across the bristles instead of with them, I imagine it would make a lot more drag, and therefore noise. It would be interesting to see a kind of feather inspired mechanism, though. A lengthwise one. (Or maybe both, and compare them)
Yes,the approach,breakover,and departure angles limit our ability to run the bristles longitudinally,'cause they're just going to be snapped off if suspended from below these no-man's land.
A 45-degree canting,projecting rearwards would be my compromise.If they strike,they'll just deform and scrub and rebound once past the obstacle.
I have no idea if they'll modify the flow at all.
I do know that the wheels are responsible for significant drag so they're worth messin' around with.
In my perfect world,I'd have hinged fairings which fire to a stowed position when a forward-looking ranging device detected proximity to an approaching hazard,then re-deploying once past the danger.They'd go all the way within a fraction of a millimeter of the road,shunting all the air around the tires,then boat-tailing to kill any would-be turbulence behind.
Pre-preg carbon-fiber fairings would be the easy part.The acoustic or radio ranging part would have to be left to a certain radio-head I know.
In daylight,one could just manually hit a solenoid switch on the shift-lever or some other ergonomic location.
After dark,or in inclement weather,you'd want an electronic eye minding the store.
