Old 01-30-2012, 11:13 PM   #4 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by Olympiadis View Post
The factory air duct is sized for WOT for passing power.
If you're cruising with your TPS between 15% and 20% then the actual cross section area of the air tube you need is very small. Unless you need to make full power at WOT, then you do not have a problem there with size.
Thanks. That makes sense.
I've always ran my WAI to the exhaust manifold , to either the factory heat-stove or one that I made. After a few minutes of driving typical temps for the WAI are between 120*F and 160*F for mine.
That's what I will do in the end with the WAI portion again. This was just for proof of concept.
What are those numbers you posted exactly?
Sorry... it's degrees F. I'll go edit it ...
IMO the best set up is using a cockpit controlled diverter valve to switch between WAI and CAI.
Agreed, but I don't have much in terms of skills and experience yet. I'm getting there. Out of curiostiy and for future reference, what hardware would you use for such a build?
