Old 01-31-2012, 01:53 PM   #400 (permalink)
3-Wheeler
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Originally Posted by jimepting View Post
Jim,
Do you yet know what the impact on the foam will be when you get the inevitable rock ding hole? Is infused water going to cause any problem with the foam?
Jim,
As for a "ding-hole" in the foam, that should not be an issue if you use materials that are not affected by water, such as the foam.
The light-weight spackling *is* affected by water, and I will not use this product on other body parts for the car in the future.
The foam, which is closed cell, is not affected by water.
Jim, are you thinking of any "foam" projects, per chance?? I get the impression something is brewing.
Jim.
