Hmmmm. Slightly out of the box but what if you had an enclosed cockpit over the driver like the Geo Metro picture that was floating around here a few years ago? You could still use a soft tonneau cover over the other half for access to storage and the occasional passenger. The boat tail area would only be as big as the driver's head and shoulders.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
