Old 02-04-2012, 05:13 PM   #195 (permalink)
G2TDI
Originally Posted by Vekke View Post
That crowwheel was from Lupo 3l brochure if I remember correctly.
Found it yes "crown wheel"
It sure does not mean that you would not get enough acceration with that torque.
Yeah I should be ok with the torque for sure
Transmission code in Lupo 3L should be DS085 shorter code can be comething else like that DSK. Regular lupo and polos have that 085 if I had understood correctly.
The codes that identify the actual gear ratios and such is always a three LETTER code on VWs (and the others in the VAG family) as is the engine codes, is your engine code "ANY"? Not sure what the 085 is but I assume it is the same as the 020, 02A etc which could be called the family code more or less refers to outer casings and bolt patterns and such.
P.S. Ok yes I saw the "085 electronic gearbox" reference now in the PDF, as well as the "the crown wheel was drilled" statement, so yes factory done.
