Old 02-06-2012, 01:37 PM   #3 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Just make sure the end of the exhaust pipe sticks out of the bellypan I would think would be enough.
That is all I did and I have had no problems with fumes. As long as your exhaust and floor aren't both rusted through you should be fine. Some folks with hotter exhausts than mine (gasoline fueled) leave out a channel of coroplast close to the pipe so the plastic doesn't melt.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
