Thread: 40 mpg s10 2.2L
Old 02-06-2012, 01:07 PM   #19 (permalink)
Olympiadis
oldschool
Olympiadis's Avatar
White2003Focus - '03 Ford Focus SE 4-door sedan
Team Ford
90 day: 38.53 mpg (US)
White2001S10pickup - '01 Chevy S10 extended cab LR
Last 3: 24.51 mpg (US)
1989DodgeOMNI - '89 Dodge Omni
Last 3: 30.38 mpg (US)
1991ChevyC1500pickup - '91 Chevy C1500
Last 3: 24.03 mpg (US)
White1986Irocz - '86 Chevy Irocz LB9
Last 3: 30.14 mpg (US)
1999 C5 Corvette - '99 Chevy Corvette
2008 Infinity G37 - '08 Infinity G37
I don't use ultragauge.
On a wide-band O2 sensor you would see your AFR drop from 14.6:1 to something lower.
This place regrinds cams for economy:
Delta Camshaft
Depending on the individual calibrations you may be able to fool the PCM to keep it out of fuel enrichment for most of the time.
For instance a TPS tricker could possibly do much of this.
Keep in mind that the enrichment is there for a reason, and part of that reason is to avoid possible engine damage under some conditions.
When you are pushing the engine loading and/or the tune, you want to keep an eye on both spark-knock sensor output, and your AFR.
There are phone apps like DashCommand that may help you do that with OBD2 systems.
The Following User Says Thank You to Olympiadis For This Useful Post:
gmcZ (02-06-2012)
