Old 02-06-2012, 08:24 PM   #4 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Here is from vol.6, no.4, p.1 of the journal nemo linked above:
Fuel trim can also be expressed as
either a positive (+) or negative (-)
percentage. The percentage reading
represents the difference either above or
below the anticipated amount. So a short
term fuel trim reading of +20 percent
indicates 20 percent more fuel had to be
added to achieve the proper air-fuel mixture.
A -20 percent short term fuel trim indicates
that fuel had to be removed by shortening
the injector pulse width to achieve the proper
air-fuel mixture.
So if my long term fuel trim is +0.78 or +1.56, I am running rich. Darn. Need to figure that out. I'm leaving a margin of FE on the table.
