Old 02-08-2012, 05:27 PM   #19 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by Mr. Previa View Post
Yep, I was hoping to use the flexible panels, but the budget didn't allow it. If I see a loss in mpg, then I will make some changes. I might start with lowering the front of the panel. Then perhaps make a small... hmm brain fart... a small deflector in front of the panel to carry the air over the panel.
Can you put it inside on the rear deck? You would lose some power but you really don't want it in the wind. And maybe there would be enough power for most purposes even if it were inside. How much power does it produce? How many watts?
