Old 02-08-2012, 09:29 PM   #3 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Since you are on the freeway it will probably be worth it.
stock is 165/70/13 weight 14lbs 22.2 inches in dia. 949 revolutions
...........175/70/13 weight 15lbs 22.7 inches in dia. 927 "
...........175/70/14 weight 15lbs 23.7 inches in dia. 886 "
the 14" tire is 7% larger in diameter. above 5% will show mpg improvement
Make sure the larger rim is not too much heavier
Check to see if there is a shock or strut tower that would limit how tall you can go.
For example:
I have the tallest tire that fits up to the bottom of the front stut tower
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
