I agree with the comments about weather and that 27% is significant. FE will be higher in the warmer months. Watch tire pressure. As for driving... I have a 1998 Civic, which is quite different from yours, but my load target is 75-80%. 85% sounds a little high. I could be wrong. Also, I shift at 2200 rpm. You might also cut the engine while waiting at longer lights (30 seconds or longer). And you might learn to do some bump starting or at least cut the engine for coasting to red lights. Those are my easiest free suggestions.
Onward!
