No problem, I can help walk you through it. If you want to do a coastdown test, your best approach is to just get started and save the calculation stuff for later.
Find a straight level stretch of road and coast both ways with a video camera on the speedometer. Use one of the free online topo map sites to find a level road. Look for 5 foot contours with no contour lines crossing the stretch of road that you will be using. Then look at the road - it should look absolutely level.
Try for zero wind. Second best is a very light breeze straight down the center of the road. Crosswinds are very bad - they act like a headwind both ways. It's a good idea to run a garbage test to work out how to do the test.
The regression equation from my test showed a 5.5 MPH wind. That light a wind almost feels like a dead calm, but you can see from the first graph just how much it affected the test.
