starting with you last comment......
how about you read some posts on tire sizes .....then pull the placebo out of you XXX.
MAYBE you would learn that the 'yahoos' don't post on this forum and we use scangauge and gps to verify our miles traveled......we don't post it if we can't prove it.
And as far as tire size.......you keep quoting tires that are the same diameter.
If you read some of the posts on tires you'd see that generally there is room for a taller tire. Of course, you have to get down and look........
or
you could try to THINK.......nay.
