Old 02-10-2012, 12:59 PM   #42 (permalink)
Olympiadis
oldschool
Olympiadis's Avatar
White2003Focus - '03 Ford Focus SE 4-door sedan
Team Ford
90 day: 38.53 mpg (US)
White2001S10pickup - '01 Chevy S10 extended cab LR
Last 3: 24.51 mpg (US)
1989DodgeOMNI - '89 Dodge Omni
Last 3: 30.38 mpg (US)
1991ChevyC1500pickup - '91 Chevy C1500
Last 3: 24.03 mpg (US)
White1986Irocz - '86 Chevy Irocz LB9
Last 3: 30.14 mpg (US)
1999 C5 Corvette - '99 Chevy Corvette
2008 Infinity G37 - '08 Infinity G37
For increasing throttle resolution, if you're not big on modifying your throttle lever attaching point, you can sometimes do it a very easy and temporary way with a piece of aluminum foil crushed and pushed into the cam-shaped throttle cable groove on your throttle lever.
Just keep in mind the point is to make the gas pedal less sensitive at very low throttle positions. Make sure you pre-test it to make sure the cable stays aligned and isn't in danger of coming out of the groove, or binding. (safety)
Here's a pic to try to help with the explanation.
http://i702.photobucket.com/albums/w...cablephoto.jpg
