You would attach it to the under carriage...... It would never be 'lose'.
Prospect Fastener Corporation | Cable clamps, Snap rings, Retaining rings, Roll pins
Series COL
Extruded EPDM cushion for added protection and durability. Stainless steel available, as well as neoprene or silicone cushions. Offset in lower leg (through 2.75" clamping diameter) to allow flush surface mount.
•Round top hole, slotted lower hole for easy alignment
•HD galvanized or stainless steel
•.187" - 4" clamping diameter
