Originally Posted by Arragonis
I tried routing warm air to the intake but it made no difference, but a straight radiator block did. Its off now as the car is due a service and I have some warranty issues I want sorting and don't want any excuses from the garage.
There have been a few threads on WAI and similar experiments - will look forward to any new ones out there.
My car is MAP equipped, which supposedly is good for HAI's.
I can tell you a couple of things about how much better it is when the AIT is at different temps.
First, there is a section of road I travel Mon-Fri coming home from work and it is less than 2 miles from startup, is on the highway where I am on CC at 58 mph.
With the UG showing the coolant is already at 185f, when cresting the hill it flattens out for a half mile and the AIT will be somewhere around +20 over ambient, the instant MPG shows 37-43.
When cresting the same hill after having driven for a while and the AIT is 40f over ambient, the instant MPG gauge will show 48-55.
At 60f over ambient on the HAI, it will show 65+ mpg.
Second, is when the coolant shows 185f but the AIT is at 60f, it only takes 50% load to get to 2 GPH burn rate on the UG.
When the AIT is at 120f, it takes 85% load to get the same GPH burn rate.
Unless the UG is lying, it looks like HAI works well on my car.
