typical stupid statement:
"my stock tires wouldnt even fit on your car so when it comes to the weight you wouldnt even understand."
WHy would i want your tire on my car??? What purpose does that staetement serve? How is that relevant?
And don't get going on the weight issue. I'm the guy that explains moving weight being 4 times the static weight as a reason (to concider) in NOT going up on rim size.
But since you don't read.....you look silly.
ANd
"tire to strut is not the only clearance issue with a car. assuming you are at stock height? and have no wheelwell clearance issues. or do you rub on tight turns but dont care?"
Again, If you would educate yourself.......
OH DAMN!!!! WHO WOULD HAVE THOUGHT!!!!!!! with 255,000 miles, I wondered why there were rubbing noises!!!!!! You are so smart!!!!!!
Of course, there are other conciderations....duh........
AGAIN, If you were reading instead of 'dumping' you'd see that eco driving is very different from ricky racer driving.
Come on, you want to waste time on a windshiel wiper shield but can't have a conversation about tires!!!!!!
I mean really.......you act like a slightly taller tire is the end of the world......'lift kit'.....geezzz.
you telll somebody else to run motorcycle tires on a car!!!!
To say you have absolutely no understanding of eco modding.....
But I'm sure you'll have some quick reply..........
See what you are clueless about is after you post on a forum 1000 times, you see a pattern in new posters......
ANd you fall in to the catagory of noobies that don't read anything except what they post.
Hey, guess what......nobody else has an Infiniti Q45 on here either.
But I read and read and then asked questions.
And very early on I realized that this was a very smart forum that could teach me alot.
So I tried stuff and tested ideas.
So don't pull this "come and test my vehicle' crap.
Test your own car.
(see if you really had read the tire forums, you'd have seen Frank Lee's post about truck tires)
