Old 02-12-2012, 06:07 PM   #16 (permalink)
racerc2000
Elle - '10 Honda Element SC
now as I said if setup correctly it could be an option. the only drawback is wear as motorcycle tires dont last as long as car tires. but maybe if setup like this you may be able to flip them side to side to get longer wear. but apparently handling isnt a problem or braking.
and many EV are going this route. so I wouldnt just toss the idea in the trash just yet.
as for testing. I will be picking up a set of motorcycle tires for my Miles zx40s as I plan to mod it to go over 45mph... and have a longer run time then 80 miles.
so when I get to work on that I will let you know the results.
The Following User Says Thank You to racerc2000 For This Useful Post:
Arctic Fox (02-12-2012)
